davet said:
LightninBoy said:
davet said:
The new rules for our Council just came out today and washers are allowed. ;
Northern Star Council rules - best scouting rules in the nation.
As an aside: LightninBoy; are the wheel weights allowed with the new rules? I thought of just using standard washers and filing the bottoms off so they were flush with the bottom of the car.
The Puma weights are not allowed per the NSC rules.
Understand, however, that the concept itself is not illegal. Its that we need to be able to check for lightened wheels without tearing the car apart. And the Puma weights - as currently designed - prevent inspection of the inner wheel.
The relevant rule is:
2.9 The complete inside and outside lettering of each wheel must be visible when the wheel is attached to the body.
So if you were to take normal washers and grind them down to provide a viewing window, that would be allowed.
