Axle Slot Cutting (K House Groove)
GravityX
Pro Racer
Feb 25, 2012
3,538
84
48
Tornado Alley
I was playing around tonight trying to cut a better K House groove and came up with this technique. The result was a nice clean deep groove. So, now the screwdriver will not jump out of the groove creating a torn up axle head.
Here is the setup...
...and here are the results.
Gravity.....would it not be possible to do the k house groove on your mill? Are the axles heads to small or they don't make a mill end that size ?
I'm sure there are end mill bits small enough to cut a groove of this size, but this is what I had on hand without spending any money to buy a miniature bit.
Budget constrictions. I totally understand.
Didn't know if it was just more difficult with the mill. It would be nice to line up four or more and take care of it one swoop.
This is really cool!! I had to cut my groove a little deeper too so I could use the screwdriver again, but mine doesn't look as good as yours.
I have been using slitting saws in the 0.014" - 0.016" range with the axle "chucked" into a block in my X-Y vise. That way I am able to control depth of cut and cut across the axle. Once set up, they all get cut in the middle. I know it's overkill, but if you buy a bunch of axles at one time, it pays off. If you only have to slot one set of axles at a time, then it's probably not worth the setup time and you are better off with the small miter box. I have both setups.
BTW, I am not using a regular screw driver. The size I mentioned is for using more like a eyeglass screwdriver from a precision screw driver set.
Can I get a picture of your setup. I'm looking for a setup with an 1/8" arbor to fit the collet I'm using.
That's almost exactly what I do, though my tools aren't as sophisticated. I use a Dremel and Dremel workstation, positioned vertically just as you have. To hold the axle, I ... uh ...
<looks both ways>
use
<leans in to whisper>
the DW axle straightener tool and a small clamp to squeeze it tight.
I rest that on the dremel workstation table and slide it gently into the spinning cutting wheel. The biggest challenge is setting the correct height with the Dremel workstation to get a groove in the center of the axle head because the workstation moves the Dremel up slightly when I tighten the position.
Anyways, the main point is that the concept you showed is solid and can be achieved with a variety of tools.
I use a small end mill, but its still not as thin of a slot as Paul is getting. There is some play as the slot is wider than the screwdriver, but it still works well. I have tried smaller end mills, but they end up breaking very easily.
I like Pauls method better, I am going to give it a try.
<looks both ways>
use
So do I. The tool gives me a nice reference line to use when I manually line up the cutting wheel of the Dremel to the center of the head.
Oh... I agree! I was just looking for an easier method than what I was currently employing. This is what I came up with what I had on hand. Works better than my previous method, by this I mean it saves me time.
Be on the look out, I'll have that tool I previously used for sale soon along with a few other items. Stay tuned.
