I helped my son build his pinewood derby car for scouts and it bounces around going down the track rather than rail riding. The rear holes are drilled at 2.5 degrees. When moving the car forward one wheel goes out to the head of the axle and the other slides up against the car and when the car is rolled backwards both whens go to the axle heads and stay there so I know the one hole is off alittle. whats the best way to fix this issue. The COG is 7/8 inch in front of the rear axle. Any help is much appreciated.
