Billy's Red Neck Ask The Pros Polish Puzzle Post....Paper, Polish.... Practice !!
Feb 23, 2015
518
143
43
73
Gulfport Ms.
During one of his many overnight sleep overs at the Nervous Hospital, if it was the pills or an ephiany it occurred to Billy that speed axles are a certain OD for a reason. One of which being stability within the bore/axle fitment.
Paper, by design, is made to remove material with the super fine grits giving a glossy finish during the final phase. The big dummy's though process may be skewed but why piddle with paper when a polished product is preferred ?
If Billy's right or wrong nobody knows like the Pros knows so here goes...should a polish only approach be done at the low speed of a variable drill or press or is it okay to use light shaft pressure using a Dremel at a low or high speed ? Curious about the Dremel and what speed as the knucklehead has spent $1.64 cents on 2 joist hangers to build his Mullet. An all business in the front and a party in the back axle head slotter and shaft polisher.
