I was reading some older posts and seen mention of "bead tests" on Red Rocket. The posts seem to indicate that oil beads up on these like water does on wax. And that this is the preferred result? What is the theory behind why this is better? Is it because the oil has less "sticky" properties when in tiny beads? But beading would make me think the entire surface isn't coated with the oil?
The same post implied that the oil beads up on Jig a Loo also. If the properties of these two are similar why not just use the Red Rocket on both the wheel bore and the axle?
Playing around in the shop I tested some stuff I had sitting around. It was some silicone spray and a couple waxes. I polished an area of an anodized piece of a aluminim with each and also left an area untouched. I then put a drop of Krytox on each of the surfaces and spread the oil out with my finger. Interesting results.... one of the waxes beaded the oil FAR more than either the silicone spray or the other wax or the untreated surface.
