Yes, but it's not an easy task to bend a polished, non-grooved Awana axle without doing damage.5° positive camber / and 1° toe in.
Do your rules allow you to bend your front axle?
Put your k-house slot on the head, polish it up, and try this method from one of the greats. This works on Awana axles.Yes, but it's not an easy task to bend a polished, non-grooved Awana axle without doing damage.
Hoping to help out a bunch of kids get fast(er).
20! That sounds crazy! Is the issue bending the axle or putting the groove in? Or both?Yeah, doing three or four wouldn't be a problem. There's about 20 kids though.
Still have to heat treat and sand about .001 off o.d. Bushings are 7/8 long and reamed to .090 which is just a smidge tight for a 2.3 mm drill. May have to hone using a drill and lapping compound.That’s great! Maybe you can post some pics once it’s finished.
