Cheetah kiss axle polish
Mar 3, 2015
77
I ordered this from John. I misread the description and I thought it was a second polish after the zero friction axle polish. After I reread it I see the zero friction polish is replaced by it. Is that right? Also on the final step should I clean the axles with pledge or window cleaner? Thanks for any suggestions.
yes the kiss polish is new.. use it instead of the other clean axles with window cleaner then pledge if using graphite, if using oil the put jig on axles.
Thanks Tre! We have the whole pack gunning for us this year. We beat them pretty bad last year so we need all the help we can get. Hopefully my son and I can get this car put together by Sunday.
NeedforSpeed-
You guys can Get R Done!!!! Just follow all your instructions and make sure to keep everything clean.. Once you Whoop Um please post the photos so we can see..
GOOD LUCK this SUNDAY!!!!
smile
