GravityX said:
HurriCrane Racing said:
I always cut my body before drilling. Cutting the body can release tension in the block and warp your drill if done before cutting.
Question: What aspect of the drilled hole is being warped? Just curious. I want to see if we are on the same page here.
The drilled hole is not warped. The body itself will slightly warp when I rip cut it down to 1/4".
This can throw off the cant. What I have seen is that one wheel will migrate much quicker than the other. This leads me to believe that the degree of cant has changed because both wheels popped out to the axel heads quickly and evenly before I cut the block down.
Like Kinser said, it may all just come down to preference. Cutting the body down first is what works more consistently for me.
