When drilling canted rear axles with a Silver Bullet or The Block, is there a way to setup a two-fence system that doesn't move and allows a perfectly lined up left and right side? I understand how I can use one fence at the bottom of the SB and draw a line on the wood for both sides and just flip it over, but I imagine it's very hard to get the other side's line drawn perfectly, and also very hard to drill on the line exactly the same on both side. Ideally, there would be a way to setup the drill height fence, but also setup a fore-aft fence, that is never moved. The fore-aft fence would ensure the whole on both sides are perfectly aligned down to the tightest tolerance.
Or, should I just use the fence for height, and draw the lines on both sides? Does it matter if the axles are off 0.003 fore-aft? How close can you really expect to get trying to line up the drill press on a 0.5mm line?
