The new fast times present interesting changes one must make to model the track now.
The unlimited class is so fast, you have to make a few changes or you are faced with a car going faster than it could go on a level track with a start angle of 27.1 degrees. You either force fit a shorter track, or force a steeper slope until you get the unlimited going the correct time. Then you can check and see what the SS time is and discover good correlation. Even if the track is 27.1, it would have to be allowing a small drop on the flat to get such low times. In that case one would assume a flat track and force the higher angle anyway..
Use a coefficient of friction of 0.0035 for the unlimited and then calculate the starting angle to give the fastest time on the track. Those two fast runs probably were perfect. After you come up with a new angle, PM me to compare. Hint, it is not over 28.5 degrees.
