Inner and outer wheel hubs
Feb 24, 2014
21
I've always chamfered my inner and outer wheel hubs to reduce service area again the car or the axle head. Just curious what everyone thinks about this. Douse is make a difference or is it a waste of time.
I'm using a pro hub tool that just uses sand paper to shape them. It works pretty well but takes forever. A lathe would probably work better if I had one. Any ideas?
Without a lathe, my recommendations would be to purchase a set from a vendor to see how what the finished product looks like. I don't know of any methods, outside of a lathe, that could produce the same quality of chamfer, or coning, onto the hub area.
I personally would not modify the hubs with the "Pro Hub Tool." I have tried that early on and never had much success (with BSA wheels). Since I do not have the ability to turn wheels properly, I just purchase them according to the spirit of the rules.
I believe you would be faster just polishing the hubs.
I've done alright using the pro hub tool you just have to be careful. Our rules don't allow us to use any other wheels except the ones provided with the kit.
The AGP wheels are very sharply squared at the inner hub. You are indeed well served to use the pro hub tool there. Use a fine grit to finish the sanding and then polish.
I've looked at some of our AGP cars after racing with unmodified hubs and there was a groove worn into the side of the body from the hub; that can't have been fast. /images/boards/smilies/smile.gif I now harden the wood where the front wheel contacts it by burnishing it by pressing hard with the back of a spoon.
