I thought this was a pretty good deal for what it is. It comes with a hard case, a neat little tripod, and a magnetic mount. It works awesome for setting up the track! The manual says it's made by Bosch. Very bright line.
Yep, the pic is the link. May not work if you're on a phone?
With the laser's plumb line you can make sure your hill is set up dead vertical and not leaning to one side. Then I set it on the finish line bridge pointing towards the hill and align the flat to the hill. I still use a digital level to make sure each track section is level in both directions and to set the hill angle.
