Ok, so team TBR has graduated to using oil - almost. We are in the process of converting a couple of cars along with TBR Jr. building our first car designed to use oil.
On one of the cars we are converting to oil, we ran some tests with the new axles and wheels. I then let it sit for just over two weeks with the occasional few passes. I did this to see how long the oil/prep would last. The car slowed down some and I am trying to figure out all of the contributing factors. I know that dirty wheels, slight hub damage ( from having the gap too tight) and a very small piece of lint all had some contribution to the loss of speed. The question remains for us is did the timeframe and/or too much oil contribute? I was using the black Ice system along with the Hater Sauce.
While disassembling this car I noticed several droplets of oil on each axle. This was in addition to the small droplets I could see in each wheel bore. I am wondering if I may have had too much oil on each wheel? I probably should have taken some pictures???
I watched the Oil Secrets Released video in the premium section. In it John used significantly more oil than I did. Based on what I had read prior to that "less is more". I used 3-4 of the smallest drops I could get out of that dropper (they still seemed large). One on each race of the axle and the third on the outer race surface of the axle.
I have also read that the oil process will "appear dry by race day". So after 2+ weeks and about 35-40 passes, upon disassembly, I could easily see (even with the naked eye) oil droplets in the bore and on the axle. Is this too much oil?
So now for another first ...re-prep of an oil wheel /axle combination.. Another thing to learn and to try and master.
So much to learn and so little time...........
