I picked this up a few months ago after wrestling with that 30 year old drill press. I just didn't feel It was exact enough and the Run Out was more then I wanted to accept. So I found this drill on Amazon (SE 97511MDP) Lol no name
Pros:
1. 85 dollars
2. Run out is almost nil
3. High Speed (8,000 rpm)
4. Variable speed (dial switch)
5. once finally setup, seems to be very exact!
Cons:
1. Base is off by about 1/16
2. un-adjustable base
3. base is made out of some cheap cast of some sort.
I purchased a t4 aluminum 1/4x4x14 plate and epoxied 1 1/4 aluminum angle bar to it. I bolted the plate to the base plate (slotted it for play). So adjustments will be a pain if I want to drill something other than the Rears or DFW. I set it up to drill the rears with a spacer then when I drill the DFW I can remove the spacer. I've only done 3 cars but test drilled about 100 times. lol
Do I wish I bought the Proxxon, yes but also wish I had a bottomless pocket book too. Maybe in a few years!
Link:
http://www.amazon.com/gp/product/B0040YJTTU/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Pros:
1. 85 dollars
Cons:
Link:
