Power Tool Pro's, Billy's Red Neck Dremel On The DL But Up From Triple A Comes The Rookie Phenom
Feb 23, 2015
518
143
43
73
Gulfport Ms.
Billy's Dermel Tool is on the disabled list but the rookie phenom Hobby Rotary Tool to make his MLD (Major League Dremel) debut. Before ordering his new uniform if it doesn't fit Billy must acquit . The rookies neck size is .792/3ish. He needs to know if this new attachment will fit ? No response from Ebay seller so far !!
https://www.ebay.com/itm/Dremel-Rot...Kit/254013350046?_trksid=p2485497.m4902.l9144
The measurement sounds about right, everybody copied thr dermal.
Look into th plung router attachment it has adjustable depth, it's just a nicer tool.
You'll need to make more than one pass to get down to your target depth when cutting weight pockets.
If you try and do it all at once it will burn up the block & smoke the bit.
I think the thing is about $35 on amazon & a pack of 2 bits is $9 .
Reactions: ratrodsrule1
, Billy The measurement sounds about right, everybody copied thr dermal.
Thanks Jup
Jup...check this out. Looks like a good price and free delivery to my door ?????????
https://www.homedepot.com/p/Dremel-...5s_UG6XKfR0BTOgOQkBoCXPIQAvD_BwE&gclsrc=aw.ds
