SoGone has one of those mills. I looked at it, and if I had it to do over again, I would get the mill. It does both drilling and milling of weight pockets, body holes, etc. I will also do the wheel holes.derbychip said:Ok Ill Be Ordering Tonight, But Now Im Unure If I Want The Drill Or The Proxxon Mill Will The Mill Do EverythIs It Worth The Extra?ing The Drill Does (Drill Axle Holes) And More is
B_Regal Racing said:There has been a ton of discussions around here regarding drill presses.
I don't want to talk you out of a Proxxon Drill Press, but when I bought my press, I did assume that I would have other uses for it, other than PWD. In my own research, it seems that Proxxon was more or less geared for the hobbyist. I went with the Skil 3320 instead. It is true that the "Block" did help me increase speed (you'll see the increase in "Ghost" this weekend), but in reading a lot on using the "Block", the accuracy of the Proxxon was not an absolute. There are some here who use a good press, not a Proxxon, and are very competitive. Here is a few threads on "Drill Presses" worth reading in case you want to consider alternatives; it has the advantages and dis advantages of the Proxxon
http://www.pinewoodderbyonline.com/post/drill-press-6714062?highlight=drill+press&pid=1281226369#post1281226369
http://www.pinewoodderbyonline.com/post/drill-press-6781396?highlight=drill+press&pid=1282635804#post1282635804
http://www.pinewoodderbyonline.com/post/drill-press-choice-5667835?highlight=drill+press&trail=15
One more thread about the necessity (or rather, lack there of) of a perfectly square table
http://www.pinewoodderbyonline.com/post/drill-press-5601096?highlight=drill+press&trail=15
GravityX said:Get the mill, you can't mill with the drill, but you can drill with the mill.
I've drilled most of my cars with the mill, takes a little bit to set things up but once you do it's real easy.
can you explain what you mean here "i will also do the wheel holes"OPARENNEN said:SoGone has one of those mills. I looked at it, and if I had it to do over again, I would get the mill. It does both drilling and milling of weight pockets, body holes, etc. I will also do the wheel holes.derbychip said:Ok Ill Be Ordering Tonight, But Now Im Unure If I Want The Drill Or The Proxxon Mill Will The Mill Do EverythIs It Worth The Extra?ing The Drill Does (Drill Axle Holes) And More is
derbychip said:GravityX said:Get the mill, you can't mill with the drill, but you can drill with the mill.
can you explain what you mean about it takes some time to set it up, is this a every drill set up or once you verify square you dont have to redo everytime
derbychip said:can you explain what you mean here "i will also do the wheel holes"OPARENNEN said:SoGone has one of those mills. I looked at it, and if I had it to do over again, I would get the mill. It does both drilling and milling of weight pockets, body holes, etc. I will also do the wheel holes.derbychip said:Ok Ill Be Ordering Tonight, But Now Im Unure If I Want The Drill Or The Proxxon Mill Will The Mill Do EverythIs It Worth The Extra?ing The Drill Does (Drill Axle Holes) And More is
derbychip said:i'm sold on a proxxon just want to be sure im getting the one that best fits pwd
