So I'm trying to decide how to handle the new rules for my son's upcoming scout race...
All wheels must be flat on the track.
I must use the pre-cut slots in the block.
I can't use any washers
So I'm trying to decide between two options, I may end up testing both...
Option 1 - Use my trusty Silver Bullet to drill 1 degree canted rears, the wheels should still be flat on the track, but my drill press is not the best, so the drill may not be the most precise....
Option 2 - Use my brand new Silver Bullet PRO to drill the rears at zero degrees and we'll use my standard Teflon Tuff Nail Polish next to the wheels to mitigate friction from the rubbing wheel. At least this way we'll be sure to have a dead straight axle to race on.
I've never totally been satisfied with my drill jobs on the Silver Bullet, they are much better than just banging the nails into the slot, but not always perfect.
So which method would you try? Perfect Alignment with no canting? Or 1 degree canting with good migration, but slightly imperfect alignment?
