I was all set to pull the trigger on the SB Pro and realized the bushings are set up for a #43 bit, but BSA axles (I have to use BSA axles) should use a #44 bit. Is the .003 slop using a #44 bit in the jig going to negate the precision advantage of the SB Pro?
Are there bushings available for the #44 bit?
A suggestion for the next round of SB Pro's to go into production is to add a third hole with a 1 1/2 degree cant for those that have to run 4 wheels touching.
