Some RAW data from Cub Scout wheel tester
Nov 26, 2011
623
77
This is very preliminary, but just wanted to tease. Working with a few Cubs that like to test stuff. What we have is a Lowes mirror with different substrates stuck on the smooth glass back. We are just starting, and the first round of tests is to study friction on a raw wheel that has not been polished or waxed or anything. We are measuring the friction between the polystyrene wheel and the different materials it might rub against. I do not have a plain wood strip in the test yet. I use a ruler and later calculate the actual friction. All the Cubs do is slowly lift up the edge of the mirror with a few wheels on different strips, and the wheel that moves first is the winner. So a Cub can quickly test and see which things reduce friction. This needs to be repeated and continued with a bunch of other things still to do to make a complete story, but I will tell you the top green line is what you get from rubbing the aluminum track instead of rolling on it. The purple line is the stainless steel result and both the aluminum and the stainless steel numbers are right in line with published data, so I feel good about where this will all lead.
Right now, the dotted lines are in my dreams, but
smile
published for other systems and I still need to run BSA wheel to produce both the yellow and the Grey, but it should be soon. Can you imagine a poorly made car that drags on the rail all the way down? Oh boy! UPS just dropped off a box of goodies to mess with! If we get a few winners, they will remain in my dreams.
Aww man!
When I strain my brain I can barely grasp the graphs when all the info is present.
Throw in the color blind aspect, and short some info and it might as well be in Chinese.
C'mon TX,
Give me a hint!
GravityX said:
B_Regal Racing said:
laserman said:
and it might as well be in Chinese. C'mon TX, Give me a hint!
Glad to see I'm not alone.
Code:
你不是唯一的一个。
Wait a second! I think I am understanding this a bit, but it looks like Korean to me.
Ok. I think I have the colors figured out now.
The grey doted line starts with a "T" so it must be Teflon.
Well- T might be for Teflon BUT
http://youtu.be/cjyg5ylSMO0
or it might be the Delrin with Teflon?
Ok gents.
I cracked the TX Chemist code.
- molybdenum
-graphite
-moly + orange peel
-polished steel
-orange peel
-teflon+orange peel
laserman said:
Ok gents.
- molybdenum
-graphite
-moly + orange peel
-polished steel
-orange peel
-teflon+orange peel
Banana peels are slicker than orange peels.
Code:
你不是唯一的一个。
Wait a second! I think I am understanding this a bit, but it looks like Korean to me. Ok. I think I have the colors figured out now. The grey doted line starts with a "T" so it must be Teflon.
Code:
你不是唯一的一个。
Means: You're not the only one!
