In the June Championship race, I entered two unique cars in Street Stock Pro class. They should have run in the Amateur class, i.e. I should have entered them under a different name, like OPA4FLAT, since they are strict amateur cars. However, the main purpose was simply to see how well they would do against the "big boys" on a professional track.
4FLAT had an average time of 2.9908 in May, and 3.0086 in the June Championship race. I did not do any re-prepping between the 2 races. It had standard BSA wheel spacing of 4 3/8's and used DD4H Dynasty RageXtreme wheels. Had I performed a re-prep of wheels and axles, it would have averaged under 3 seconds. As it was, it still had a couple of single sub 3 runs.
4FLAT2 had an average time of 2.9989 in the June Championship race. It had a 5 inch wheel spacing with wheels moved to the rear, and it had Dynasty Cheetah wheels. Had it been amateur, it would have placed 21st. It would be legal UNDER some BSA rules, like the Grand Canyon council in Arizona
In both cases, I only prepped the wheels and axles strictly according to the DD4H DVD, mounted the wheels, added rear fenders only, and shipped the cars to Utah. I didn’t even break the cars in with advance test runs.
Both of these cars used the DD4H pre-drilled blocks requiring no tuning, but with canted rears. All four wheels touching the ground.Since they both did so well, especially since each car took me less than a day to complete, I now know it will be an easier way to go next year for my 3 grandchildren, plus several other local boys.
For example, I will now order the Pre-drilled blocks and wheels from DD4H, shape the bodyand give it to the boys to glue the fenders on, paint the car, add any decorations they want, and then I intend to let them prep the wheels and axles under my guidance, mount the wheels and axles, and go race!
Ergo, a winning sub 3 second car.
