Go to Hobby Lobby or anyone who sells Pine Cars, and buy one of their Pinewood Derby Trucks, one that has a bed.
Hollow out the bottom, and fill with lead
Also in the truck bed, buy some sheet lead, and fill it up.
Stop at somewhere about 15 ounces.
Buy a set of 4 razor wheels WITH BEARINGS, from DD4H.
Soak the bearings with Mineral Spirits, then blow them out with compressed air. I.e. don't make it 3 wheeler, use all four wheels on the ground.
Using the BLOCK or something similar, set 3 wheels absolutely parallel to the body. For the 4th wheel, DD4H will have one axle with a slight bend.
On an eight foot board with one end 2 inches high, let the car roll down and set the drift by rotating the bent wheel to about 10 to 12 inches to the left. Put the bent axle on the front right side, and rotate it to get the correct drift.
Take the car to the race, and win first place!
I have done this on several local races, and always ran away with the trophy.
Indecently, very few of the competition will spend much time on the wheel setup. They all thinnk of weight, but seldom of things like drift and meticulous setting wheels correctly.
