I recently bought a VANDA-LAY INDUSTRIES, Hold-It Plus Jr. rotary tool holder to use while polishing axles and thought I would share some thoughts on it.
PROS:
- The Hold-It Plus Jr.is made of solid aluminum.
- Easy to assemble with all of the required hardware provided.
- The holder is compact.
- The holder holds my True Value rotary tool really well, but not sure how it would hold other rotary tools without more testing.
- Has 4 mounting holes in the plate, so the holder could be mounted just about anywhere.
CONS:
- The holder is not heavy enough to polish axles without mounting or clamping it to anything.
- No rubber feet provided. The aluminum base could leave scratches on a table if it slides around during use.
The Hold-It Plus Jr. bolted together in about 5 minutes without any problems. There are no instructions provided but its easy to tell where the parts needed to be bolted. I used a small "C" clamp to clamp the fixture to my table to keep it from tipping and sliding around. After clamping the holder to my table I could sit and polish and buff axles without any problems. I have not tried to mount any wheels to shine and buff the sides and tread surfaces, but I will soon. The fixture is not perfect but it's a much better solution than trying to hold your rotary tool in a vice to work on your axles
PROS:
CONS:
