So many posts about alignment and revolve around my question, but since many are old I thought I would start my own. Per what I am reading, it sounds like the rear wheels should be canted upward (top closer to car than the bottom) at about a 3 degree angle.
For a 3 wheel rail rider car, people are saying to have the front drivers wheel (DFW) downward canted (bottom of the wheel closer to the car) as that would have the least amount of drag, and then also have the axle turned slightly inward so the car steers toward the rail slightly to prevent any bouncing around on the track.
What angle should that DFW be canted downward? Should it be about 3 degrees like the rear wheels, but obviously it is the opposite direction of the rear?
What angle inward should the DFW be to have it turn in just enough? I am planning to experiment with this as many people suggest. But looking at ranges or approx people have had most success/fastest car/least bouncing. I have read testing a car on a slightly slanted board going about 4 feet and the car moving about 1", but I have also read like 6" which just seems like it would be a lot of drag wouldn't it? Again, wondering what should be a goal here.
Thanks for any help!
