Advice on Pack Rules for Pinewood Derby
AAA's question was in regard to lateral placement of the weight. Should the weight be balanced on the center line of the car, or offset to one side or the other.
AAA: I think that if you are going to set your car up to steer (very slight bend in your front axles, allowing your wheels to still run flat), you might be well-served to have a little more weight to the side of your DFW. YMMV.
And, yes, those rules are rather poorly worded. "All four wheels have to touch the track." (Cool!, I can cant them!) "This implies that the full wheel must make contact." (Huh? Why does it imply that? The whole wheel and not just the tread??) "Therefore the axle must be in straight and the full wheel must make contact." (This sounds an awful lot like, "God is love. Love is blind. Ray Charles is blind. Therefore...")
VitaminK said:
- Cut about 1/4" of wood off of the rear of the block and glue it to the front with epoxy. Cut and shape as normal. This will get your rears further back and give you a better CoM and also position the weight of the car higher on the curve.
If you measure 5/8" from the slot on the long end, and cut that off, that'll give you a bigger piece of wood to handle as you glue it to the other end. To-may-to, to-mah-to, really. /images/boards/smilies/smile.gif
Our rules are so loose, I want to race a "REAL" '64 and a 1/2 Mustang 2+2, and call it a pinewood derby car!
I'm done asking the pack for rules, I might tape a 2x4 to the roof of my '63 Ford pick-up truck, and name it, Historical Pinewood Derby Racer.
With our lack of rules, I guess---Anything Goes! (???)
Build a bearing car...that will make'em mad hahaha
angry
