So we are about to hit final assembly and low and behold the axles are a bit too loose. We drilled #43 holes and for the BSA axles we are using they aren't snug enough. My mistake, should've used a smaller bit, but it's too late now. For some neighbors' cars we helped build (also drilled #43) we cut little slivers of 400-grit sandpaper and slide them in with the axles and they seemed pretty snug, so that could work. Or, maybe, we put a few drops of glue of some kind (super glue or Elmer's or ____?) in the axle holes, let the glue dry, and then that would keep them snug. Any suggestions?
