Axle Polishing Speed
Mar 5, 2013
315
59
I've never seen this asked before.
How fast do you turn your axles when polishing? Drill press, set as fast as it'll go?
Or dremel/die grinder, really spinning them up?
We've always used the drill press...and even hand drills before I bought one, but just got wondering what everyone else used.
I use my hand drill in a clamp, at its highest speed. Not certain what RPM that is, but I think you can polish axles at high speed without worry. Not gonna melt or deform like a wheel bore would.
If you cannot reach the speeds mentioned above you'll need to polish just a bit longer with each grit. As you are not reaching the same surface speeds with the lower RPM drill motors.
My drill press maxes out at 3k rpm. I do polish a little longer. Start at 10-15 with 400 and 60 then by the time I get to 12k I do around 30s
geez, I have been doing it for several years on my little drill press, and the highest speed is 3050 rpm.
I do have an air die grinder that I could use, I would just have to have someone trigger it for me. maybe I'll try that
