Considering buying this jig. Just wondering who out there has one and what you think of it. Also wondering about the consistency and accuracy as well.
I saw in a previous thread that there is "a trick" to using the jigs. What is the trick? What variables come into play? And when used properly, what kind of consistency can be expected?
I currently use The Block from Jewkes, and after many hours of set up and test drills I get pretty consistent results. But even with that I only get a "perfect" drill on both sides ( testing with the 1 2 3 block method ) about one out of every 3 attempts. There's usualy a very slight variation on one side or the other. I attribute most of this to the quality of my drill press, but I think wood grain and other variables may also contribute to the slight variations.
I have no doubt the SB Extreme is a quality tool. And I also have no doubt that it will be more user friendly than the method I use now. Just wanting to know what kind of results I can expect before I throw another $200 at this hobby.
Appreciate any info.
