Axle question
Racaholic
Lurking
Mar 26, 2019
72
Salisbury, Md
New guy here. Hello to all you fellow pwd addicts! Rule says axles can not be smaller than .084. Would it be an advantage to go smaller? I would think the wheels would wobble.
A long long time ago, someone clever filled up the bores with epoxy, drilled small bores and ran a needle axle car and just creamed everyone. Most inspectors can't tell if the wheel got epoxy and a re-bore, but they can look for needle axles, and that morphed into a lower limit of 0.084 that many cars would actually fail when folks get carried away in sanding the axles , but the axle where the judges can see it is still OK.
Reactions: AJBinVA
It would be really cool to see a history of rule implementations with stories and reasoning. Always been a sucker for stories like that.
