Band Saw trouble
I still use my scroll saw to rip 1/2" off the kit block. It groans trying to cut through 1.75" but going slow gets the job done. I know the top isn't going to be exactly square but it is getting thinned down later on a belt sander anyway. I do route out my weight pockets before ripping it.
I might have to try that DaveG!!!!!
My compound miter box would handle that length no problem!
beats the squigglies that I get from my scroll saw
Per the PM request, here is the picture. Sorry it is not really clear, it is buried in my garage but here is what I used.
It is a 1x10 or 1x12, with a 1x4 backing, two 2x6 scrap wood guides on the sides (It was what I had laying around) holding the block in place. Adjust your saw depth to not cut completely through the 1x10 as the 1st time I went through the board not thinking. The 1x4 back plate helps prevent the thin wedge from flying back from the spinning blade. I guess if you wanted to cut a wedge you could adjust the angle of the cut, but I was just doing planks.
I use a homemade jig in my table saw. It cuts 5/16" thick bodies. Has a pair of toggle clamps to hold the body so it can't move while you cut. The waste just drops away.
Years ago I received a design for a band saw "sled" that allowed Scouts to use a 9" band saw to cut wedge shaped cars without putting their appendages at risk. I just took a look and couldn't find it, but I think the concept is fairly simple. Rockler and others sell the guides to fit in a mitre slot, then you need a body holder and some angle adjustability. Most of all, you need the ability to hold the wood in place while your hands are elsewhere.
Great ideas guys ! Thanks for the pic Dave.
I don't care how the jigs look... I am helping a couple different kids with their cars, and I want things safe... for me and for them.. LOL
This was my rough concept for the band saw sled with the planned cutout for an anticipated simple Scout car. It does not show the hold down mechanism for the wood block. Just a concept, hadn't built it yet so I am sure it could use improvements.
I have not had a problem using my table saw (Ridgid portable) to cut ~ 5/16" blanks - after removing the guard. I use a very thin push stick in the back and just about anything on the side, along with a feeler board, to position the block during the cut. This way I get 3 blanks out of a normal Scout sized block. If I want 1/4 blanks I need to use my zero clearance insert, otherwise the wood will get trapped at the end of the cut. Its worth getting the blade nicely squared before you start. Using a good blade on the table saw I can get very good flatness of the wood blanks, which I think is critical (and needs to be checked prior) to the drilling operation that follows.
