Bend or drill cant fdw ???
Rocket car said:
Axles are pro 92 s BSA bought a kit last year with 400 600 1000 1500 2000 2500 and 3000 grit sand paper then 1 micron polishing paper then 2 micron polishing paper is that good enough or do I go farther ??? But started with1000 grit first all done on drill press 10 secs for sand paper 30 secs for polishing. Will polish wheel bore and axle ,then burnish both with graphite , per rules. Any more???
I'd recommend purchasing DD4H's axle polishing kit.
The Zero Friction Axle Polish Kit includes:
400 grit 5"x4" sheet of wet/dry sandpaper
1000 grit 5"x4" sheet of wet/dry sandpaper
1500 grit 5"x4" sheet of wet/dry sandpaper
2000 grit 5"x4" sheet of wet/dry sandpaper
2500 grit 5"x4" sheet of wet/dry sandpaper
3000 grit 5"x4" sheet of wet/dry sandpaper
8000 grit 3.5"x4" sheet of wet/dry sandpaper
12000 grit 3.5"x4" sheet of wet/dry sandpaper
1 Bottle of Zero Friction Axle Polish
Leather strip for polish application
Cotton string for cleaning
DD4H's 92's . . . I'd start with 1000 grit at 5-6 seconds, and add 2 seconds of time to each grit as you go up. Polish the shaft of the axle where the wheel rides and under the head. Cut sandpaper strips 1-1/8" x 7/16" to conserve, and use only once. Wet sand don't dry sand. Let sandpaper soak for 10 minutes before using it.
If you have the tools, I'd clamp a Dremel to a table and polish axles using the Dremel at 8000 rpm instead of using a drill press.
Hope that helps.
Cygnus
