I am going to help a young Scout with his 1st PWD build (fun !) this coming weekend (one day deal) and his district rules allow axle hole drilling, but want the entire length of the axle portion which not in the wheel bore to be visible. I have never had to deal with this before. Also, I won't be there for check-in, so I need a safe, reliable method for accomplishing this.
Arguing the rule is out of the question, so please, don't go there.
The two primary options I am considering are:
1) cutting new slots (~ 1/16" wide similar to original) at the desired axle location, filling with "clear" epoxy, waiting a day for it to really harden and then drilling as normal;
2) drilling holes as normal and then using a dremel and even thinner blade to expose the bottom (only) of the axle.
The first option I would prefer from the standpoint that I can most precisely cut using my table saw and miter gauge. However I have experimented so far with Permatex, 2-part, "crystal clear" epoxy and its not so crystal clear to me (have to drill yet). The 2nd option is attractive in that you "could" control the slope of the cut for the canted rears and it doesn't requrie the mess and time lag, but its the most difficult to setup.
What has proven to the most do-able and reliable for othes with this kind of requirement ? I am open to all options.
