Billy's Red Neck Unorthodoxed Legend Box: Need Guidance Please
Feb 23, 2015
518
143
43
73
Gulfport Ms.
Legend Shipping Box From DD4H....Check
Drill Press.....Check
1 1/4" Frosner Bit....Uncheck
Router....Uncheck
I do have this mill bit for my drill press. Open for suggestions please,
Thanks.......RRR
[/ATTACH]
Router....Uncheck
Thanks.......RRR
[/ATTACH]
I have also had luck using a band saw to chop up the foam then I glue it back together to fit my cars. Ultimately I needed a method that made less of a mess and this worked for me.
Not sure if you want to give that a try.
Reactions: ratrodsrule1
THANKS CR.....I just heard a way to do the wheel holes is to glue a round piece of rough sandpaper to the face of an old wheel. Use the inner hub neck to chuck it in a drill press and Git er dun !! LOL LOL
A fishing filet knife can scrape a barbecue grate, cut of small branches of a tree, cut a good rib-eye steak into bite-sized chunks, and cut wheel holes in foam.......Don't know, but I might be a red neck!
G Body I just heard you can glue a piece of rough sand paper to the face of a old wheel. Use the inner hub to Chuck in a drill or press and git ER dun.
If you’ve ever used a filet knife to pick your 1 tooth.....you might be a Redneck
