My son is on his 3rd year of scouting and our Pinewood Derby is coming up. Each year as he grows in age and capabilities we have built progressively more complex cars. He tells me what he wants. I sketch up a design I think that he is capable of completing which he approves and he does most of the work. His designs haven't been ideal with respect to weight placement but with good wheel prep and me setting up to rail ride for him he's always been competitive (2nd in his Den both years) and has always finished just outside of the top 3 (4th and 5th) out of a pack of 70 kids.
7yo version of a Lamborghini Huracan
8yo Pokemon car
I asked him what he wants to make this year. His response was "I want a Porsche 962 like they raced in LeMans". After looking at some other pinewood derby cars he's decided he wants to build a wide body car with fenders. I took some artwork of a 962 and scaled it and started working on the design. Here is the car I have sketched up for him right now.
The wheelbase is 4.75" and the rear wheel is about 7/8" away from the end. That is about as far as I could stretch it without the scale being thrown off. The way I have it layed out is I will use his block for the main body and a 2nd block for the fenders.
I don't expect to win with this design but I would like to get him in the top 3 of his Den again so he can compete at the pack level. That's 3 places out of 11 kids which I think it doable based on past performance of the kids in the den. Most of the stuff I've read about is geared towards wedge/ladder/flat designs so I'm not sure how much is applicable to this style of car.
One question I have is for the fenders. I'm assuming all of the rail riding techniques are still applicable (Negative camber on the rears, positive camber on front drive wheel, etc). Because of the wheel hub the fenders will be just inside of the wheels themselves so they can contact the center rail first. Should we trim the fenders back so it rides on a wheel or would fender riding do the same thing?
Right now I have a hole designed in the bottom to remove weight (Orange part). Will skinning the underside for airflow make an appreciable difference? The image above will be used as the remplate to rough cut his car then it's off to rasp/file/sanding to get the final shape. Once we have it 90% shaped and glued together I'm going to see where else I can remove material. Right now I'm guessing we will be lucky if we were at 3 ounces after all the material is removed. I just wanted to run the design by some derby experts to see if I'm missing anything I should be doing with the design.
8yo Pokemon car
