bracketracer said:In my testing, drilling the front 1/8" lower than the rear (which would raise the nose) slowed the car by .011. Unfortunately, going the other way didn't net any speed! Only picked up .002 when the axle hole height was optimized. So the rule of thumb of drilling the fronts the same as the rears basically held true for me.
Question - if the nose being higher than the rear is slower (as in your situation), how do you account for the bend in the FDW? I do drill at the same height (front and rear), but my nose is always higher do to the bend.bracketracer said:In my testing, drilling the front 1/8" lower than the rear (which would raise the nose) slowed the car by .011. Unfortunately, going the other way didn't net any speed! Only picked up .002 when the axle hole height was optimized. So the rule of thumb of drilling the fronts the same as the rears basically held true for me.
B_Regal Racing said:Question - if the nose being higher than the rear is slower (as in your situation), how do you account for the bend in the FDW? I do drill at the same height (front and rear), but my nose is always higher do to the bend.bracketracer said:In my testing, drilling the front 1/8" lower than the rear (which would raise the nose) slowed the car by .011. Unfortunately, going the other way didn't net any speed! Only picked up .002 when the axle hole height was optimized. So the rule of thumb of drilling the fronts the same as the rears basically held true for me.
