Hey all....quick question, and perhaps a silly one...but according to our rules locally, the axel must sit in the slots on the block. I have no problem drilling holes on top or thru them or using the awesome block from DD4H that is precut with slots in them....but the question is....
for the 3 or 4 wheel, rail running, canted wheels, the DFW is canted to run toward the body (in addition to steering)...so the inner wheel hub will run against the body of the car at some point for the DFW, and if anything the most rubbing would likely be between the inner hub and the side of the car udner the axel (based on the cant), rather than above the axel. Im assuming if you now had slots (either already there or cut after the drilled holes) that the inner hub is now rubbing against the open slot on the side of the car under the axel....which means two edges, front and back...rather than a solid piece of wood (as it is with just axel holes....). Is that going to slow the car down any or would that be relatively insignificant as far as friction goes....
If it might be slower...then would it be better to say put some test axels in and then put putty or filler in the axel slot (just where the wheel would contact), let it dry, pull out the axel and then sand it down smooth and then do whatever your preference is (nail polish, graphite rub, that model airplane wrap material etc) so that now if you look from the side, it just looks like a drilled hole and not slot....that way the inner hub (bottom) is now rubbing on a flat surface rather than possible two edges....
Of course I guess one could just sand the edges around the slot under the axel smooth and rub graphite on it and even a little into the slot as well...or all this may be very miniscule so it may be a mute point....
opinions?
W
opinions?
W
