If I missed a previous thread in my search, apologies. I have a Skill bench drill press and have followed how to square the table to the drill and check the run out on the drill. However, when using the Silver Bullet, I noticed that one of the four corners was not touching the drill press table. With little pressure, the silver bullet would rock a small amount, even with the pin in place for drilling the rears.
Using a straight edge, it appears the outer diameter of the square table is a little higher than the middle of the table. While I know the SB jig forgives a lot of challenges through symmetry, if I were to rock forward on one side and rock back on another, it leads to one side of the rear wheels not migrating out to heads going forward fairly consistently.
I have tried to brace the jig or shim a side but that is a little clumsy. Do I need to sand down the table? Anyone else run into this? Is there a better fix? Purchase a overlay table?
As an aside, thank you to all who have shared so much knowledge. My son won his pack last night and the two tigers I helped with the info learned here placed 2nd and 4th. This year my son was able to do a lot more of the build thanks to techniques shared here. The dremmel press allowed him to do his own pockets. He still prefers to hand sand however since he finds the belt sander too scary.
