G
Guest
Guest
Drill Blocks remaining = SOLD OUT!
I will be machining (6) of the drill fixtures tomorrow. I have had a lot of e-mails and PM's in the past few months about them and just have not had time to machine more until now. (2) of the blocks are already sold so I have (5) left to sell. These blocks have 4 hardened drill bushings, 2 at 3 degrees and the other 2 are straight for your front wheels or they are perfect for the Unlimiteds and Eliminators with full length rear axles. I have sold a ton of these blocks in the past with many, success stories to back the product up. The only issues I had heard of in the past was, some racers would like the fixture marked so they could quickly tell which side was straight holes and what side was 3 degree holes. This will be fixed on this run and each side will be engraved to tell. The other issue was, the 1st runs I used steel bushings and some just gave out too soon. I now use the highest quality hardened bushings and they will last the lifetime of the tool. This tool allows the user to drill perfectly canted holes, or straight holes, with no more than a drill bit and a pin vise. This will be last run for a long time again. I will keep the total left updated at the top of this post. Blocks are $75 + $3 shipping
This is, 1st come, 1st served. PM me if you want 1 and i will give you payment instructions.
