[font="times new roman, times, serif"]Briand[/font]
[font="times new roman, times, serif"] In my opinion with this Xtremely fast league you need as much tungsten/lead weight as possible, and you need to focus on all the aspects of the build process. Each little detail can gain you a tiny amount of speed, therefore, every little step will add up in the speed department and might gain you a tenth of a second which may seem worthless but that one little tenth is the difference between first and fifth or worse. I think the computer timer reads to the ten thousandth so EVERY little detail is crucial if you want to compete! Also, what wood block are you using? Sugar pine is lighter and that is what the top dawgs are using. Take a look at the pictures and the videos here on the forum and study them well and I even take notes on what and where I saw/read it! Best of luck to ya[/font]
