G
Guest
Guest
What kind of tooling is used to remove the outer steps on a bsa wheel and leave that nice coned hub?
JimmyStile said:B legal, I have been machining my own wheels since May of this year. I bought a mini lathe and since then have made my own tooling, wheel jigs, and dissected a couple of bsa wheels. i have gotten my wheels down to 1.2 grams, I weigh them on a lyman powder scale, with awesome results. I want to know how that convex curve is put where the two step is on the outer face of the wheel hub. ya know, is it a hollow ground 4 fluted end mill, or is the tooling a half radius in a tool post. Im just wondering how that machining is done to the outer hub?
laserman said:Do fill us in. Is it an endmill or a half round?
B_Regal Racing said:DD4H... If you modify a set of wheels with this tool, you'll most likely be faster with a set of unmodified wheels, given the same prep, from what I have found. I have mauled more than a few wheels trying to get it right.
I have all of the "classic" tools; I'm sure I spent upwards around $200 for the hub shaver, pro hub tool, the axle "straightener", the axle "bender", the wheel shaver, etc. The list goes on and on. I'm sure someone may have had some success, but from my experience, I have ruined more wheels and axles than I can count. I can not believe I was pounding on axles with a hammer to bend them for the FDW (and I'm not talking about tapping a screwdriver in a bend groove). There was a time where I considered looking for a used tread mill; fortunately, this site saved me from that expense.Tekcor1 said:Are you saying the wheels will run better if run stock than if the wheels are prepped with this tool? I'm getting ready for a powderpuff derby and looking to improve my wheel prep from last year. I was considering buying that tool to prep the hubs, but maybe I shouldn't be?B_Regal Racing said:DD4H... If you modify a set of wheels with this tool, you'll most likely be faster with a set of unmodified wheels, given the same prep, from what I have found. I have mauled more than a few wheels trying to get it right.
This is what I meant to say instead of that long-winded "war and peace" post.hatfam said:yes, most of us here have tried "those tools" to improve our cars and they tend to hurt more than help. I would leave them or better yet follow B Regals advice and purchase the Dynasty BASX or Rage, depending on your rules. You will not be sorry /images/boards/smilies/smile.gif
BSB racing said:JimmyStile said:B legal, I have been machining my own wheels since May of this year. I bought a mini lathe and since then have made my own tooling, wheel jigs, and dissected a couple of bsa wheels. i have gotten my wheels down to 1.2 grams, I weigh them on a lyman powder scale, with awesome results. I want to know how that convex curve is put where the two step is on the outer face of the wheel hub. ya know, is it a hollow ground 4 fluted end mill, or is the tooling a half radius in a tool post. Im just wondering how that machining is done to the outer hub?
It doesn't have to be anything fancy. You guys are making this way too difficult. All that needs to be done is to face the surface where the step is till the step is gone. Your face cut will now be perpendicular with the bore, make an angled cut away from your faced area leaving just a tiny ring of the original surface you faced. (.005 to .015) wide ring will do. This can all be done with the same tool bit if set up properly.![]()
