Another area of consideration when we look at how light can the front wheel get, is that the friction between the wheel and the rail, the friction between the wheel and wood or Delrin or whatever, is NOT a constant, and it does NOT go the way you might think. The lighter the force between the polystyrene and the object, the higher the friction. There is a zone where increased steer drops friction but then is reversed when more of the wheel rubs over a longer path on the rail so it is not just "stability" changing with steer. Some builders find increased angle of bend on DFW gives higher speed. That can be due to more pressure (weight) against the body which reduces friction depending on how you treat the side of your car. So moving a tuning weight around on your car can be doing a number of interesting things that will not be the same on every car. Many have tested Delrin and said- no good, others are very happy with it. Here is a look at 13 different Delrins. The two best ones match graphite, and some are way worse than monokote.
