Ok I apologize for this beginner newby post but I'm trying to figure out what I'm doing wrong that is causing our car's to be so slow. I'm sure that my axle and wheel polishing is just not as precise as others but I do my best to try to follow the steps in the Black Ice process. I know I also struggle to get the alignment absolutely perfect which most likely adds to the problem. I freely acknowledge that both of these could be causing slower than optimal times but how much I'm not sure. I do have a couple of specific questions though:
1. Am I screwing up by drilling the car prior to trimming and routing?
2. Is there a necessary window after applying Jig when the oil should be applied? I know that it needs at least 15min to gas off before inserting into the wheel bore, but I guess my question is if it is possible to wait too long. If Jig sits on the axle for over an hour before applying oil, does that reduce its effectiveness?
3. Also, after bringing cars home from MA, I looked them over again and noticed a few fairly wobbly wheels. Is slight wobble accepted with an imperfect wheel or is it going to kill a car's time. My guess is that this could have occurred from removing the wheel from the body by pulling on the wheel; probably not a great idea.
4. One other thing I'm not as detailed on is weight balance and squeezing as much out of weight placement as I can. I'm not sure how much this would change things.
I acknowledge that I have a long way to go and am very much an amateur trying to figure out if getting an oil car without fenders down from 1.95 to 1.91 or 1.92 is something bigger than these or is, most likely, a combination of everything.
Again, I really apologize for the newby questions but any guidance is very much appreciated.
