We only race scout races and don't have the experience most here do. We went from not qualifying for Districts to taking 1st in Districts the next 2 years with stock parts using advice from the guys here. Since your wheels and axles probably picked up some debris from racing and from sitting around, unless you kept it in a bag, I would reprep. The following is how we reprep for oil. We have only built 5 cars and some say we don't have the best techniques but this has worked for us. It's Pretty quick and better than not reprepping I would think.
You may want to get a cheap battery operated metal etcher from Menards for $5.00 and mark your axles where they are in the car at the 12:00 position. Pocket knife will make a noticeable scratch too if need be, Take them out individually and keep the wheels mated to the corresponding axles and mark which corner they came from. I put the axle in the wheel then put some blue tape on the pointed end of the axle and mark the tape RR, RF, etc.
Doing one wheel/axle combo at a time, put your wheels and axles in alcohol and clean. Get the axles/wheels out and dry them with a lint free rag. Hit them with a hairdryer for a few seconds to make sure they're dry. Stand the axles up in holes in a piece of cardboard. Have the cardboard marked RR, RF, etc at the holes. If you have a magnifying glass or cheaters check the bores and axles for lint. Respray the axles with whatever you're using. We use 3M Dry-Type Silicone from NAPA. I'm sure there is better stuff but this works for us. Cover with a paint can cap or the cap from the spray. An hour later respray again and recover.
Wax and polish the bores of the wheels again. We wax and polish 3 times.
We let our sprayed axles set for a few days before we assemble but you don't have that time so I would say the axles would be fine an hour after being sprayed. We also hit them with the hairdryer for a few minutes before assembly.
Oil and reassemble. Have the etched mark on the axles in the 12:00 position as when you took them out. You can then set your steer. Your rear alignment will be the same as it ran in the Pack race. Fresh wheels, axles and oil. We then put the car into a large zip-lock bag with the end open until we transport to the race then we zip it up.
My OCD kicked in when we didn't qualify for Districts our second year and I came here and read everything I could. I think I've spent more time on this forum reading and studying what the fast guys do than I spent on my college schoolwork.
Good luck!
