After getting the Silver Bullet Extreme I still could not drill perfectly aligned body holes for axles.
This is my solution:
I placed 1-2-3 blocks so that the drill would be slightly toe-in and then used caulking to attach everything down to a steel plate. The harbor freight magnets are just there to steady things as I was testing the set-up.
Then at the outer most point (4 inches from the SBE) i shimmed both sides for a perfect alignment drill.
Then with a piece of wood that works on both sides of the jig, i get exactly identical angles of drill.
I use a 6 inch #43 bit to do the drilling and I can drill them slowly, clearing chips as i go.
This jig will drill identically on each block.
I find it necessary to hold the drill bit at the critical alignment point for proper consistency.
