Hey guys, my sons derby is coming up and I'm assisting him.  He wants to drill the axle holes and move the wheels further back.  So we go a basic jig.  The problem is he cut the car out and sanded it, and in sanding the car to round all the corners, with a belt sander, the sides lost a bit of wood.  Now getting the block in the jig straight is a challenge.
The angles will be off since there is a tiny gap in the side between the wood block and the jog. I'm also not wanting to just rest one side on the jig because the car may not be perfectly straight.
I'm thinking the best way would be to stand the car on the back end, and then put the jig in place with something flat to hold it up enough, then clamp the two together. That's my best idea.
Should i just suggest bending the axles and rotating them to align the wheels? If the axel holes ar crooked, one will be at an angle slightly in front of the other. I don't really know the best way to get straight axels. We should have drilled first! Doh!!
