This should get you started...
http://forums.derbydad4hire.com/post/Keys-to-win-from-the-Pinewood-Derby-king!-5782181
vdutel said:Well I have some questions to ask ... Now we are going to head into the Derby Car .. So baby boomers hang on .. lol
So here I go..
Building a car for street stock -
Type of wood- I do have several pinecar blocks I can cut?
Suggestions on thickness- I plan on using 1/4" weights - If cut to 1/4" and add planking to top and bottom of car to cover weight area.. I have seen cars done where car is milled out so the top is left solid then cover or fill bottom of car. Is there one better over the other?
Length : Should I plan to use 7" maximum allowed.
Width : Not to exceed 2-3/4" Stay with this or a bit under to keep wheels closer to rail to prevent side to side wobble?
Weight Placement- certain cars show weight placement in front of axles and a cut out in the rear of car behind axles. What I gather if correct is based on (COM) and balancing of car as to how much in front of axle and if needed you use the back slot?
Wheel Base- Extended more stable? with the above width adjustment... Rail Ride?
Axles/Wheels- I will order from DD4H ..
Well this gets me started until I can order DVD . Hoping end of mnoth .. X-ing fingers for a good bonus this month...
Thank You
V
