I've actually lived in one for a year in Iraq. It's really not that bad. Had a phone, TV with cable and AC.
Aint nothing wrong with the U.S. Air Force...HoooRahObsessedderbydad said:Must of been air force![]()
Obsessedderbydad said:Yes. C130 jet engine mechanic
B_Regal Racing said:See ya at Oshkosh then.
We need something like that for NPWDRL, or maybe "that" just happened at MA...
DerbyDad4Hire said:There will be a change coming to the NPWDRL! We will be racing this class in MAY!
We are going to introduce the BASX Class! After the May race we will eliminate the Novice division in Street Stock.
Car Body / Dimensions
Wheel Base : Any
Height : Not to exceed 3″ inches…
Length : Not to exceed 7″ inches…
Width : Not to exceed 1-3/4″ inches…
Weight : Not to exceed 5.0 ounces (143 grams) measured on 1/10th digital scale
Additional materials maybe added as long as they meet the rules
Wood must be used to construct your own body and/or frame
4 Axles & Wheels must be installed to the side of the car body directly across from one another / No more than a 10 degree angle
NO FENDERS OR ANY AERODYNAMIC MODIFICATIONS OR DECORATIONS ALLOWED MOUNTED TO THE SIDES OF THE CARS
Track Center Rail Height : 1/4″ inch ( 7mm ) *
Track Center Rail Width : 1 5/8″ inches (4.2 cm) *
* Wheels must clear the outside to outside center rail width measurement
Axles
a. Minimum diameter .084
b. Axles must have a nail head
Wheels
BSA
a. May be CnCed, lathed, polished and/or sanded to true the edge of tread, surface and circumference
b. The tread / contact surface must remain flat and parallel to the bore as humanly possible
c. No Angling, Reshaping, Canting, Round Crowning, Tapering, H-ing, V-ing, Dishing, the outside of the wheels and/or tread surface
d. All markings must remain visible on the inside and outside of the wheel including tread bumps.
e. NO Wheel covers may be used
f. 8.00mm Minimum Tread Width
g. Wheels must weigh at least 2.4 grams and a wheel can be removed after the race to be weighed to confirm weight.
h. The wheels can be trued to get to the 2.4 gram weight but they are not to be cut down intentionally under the weight limit and use foreign material to bring it back to weight.
The following Modifications are not allowed
a. Starting or finish line devices
b. Electronic or lighting devices
c. Glass or extremely fragile parts
d. Paint that is wet, smudges or extremely sticky
e. Bearings and/or Bushings
f. Sharp objects, sandpaper or abrasives on the bottom of car (We do not want any damage to the rubber stopping pads)
g. Axles and/or wheels attached to any device that mechanically or alters rotation and spin
h. Any part of the car to go beyond the starting peg (see photo below)
j. Propellants
