A Q-tip's shaft can be to big. Combine that with the speed of the dremel and you'll melt the bore.
I was referring to only letting the cotton swab (not shaft) rotate in the dremel while pressing gently against the inner and outer hub. (with polish).
I too have stripped some bore off my wheels with a q-tip shaft on my dremel. As of now I use a q-tip in the dremel with DD4H step 1 polish for the bores. My only option for using a q-tip shaft would be to use my drill and hope that I can hold the wheel with one hand and gently squeeze the trigger with the other so that I have a moderate speed (my drill cannot be set at a speed and its controlled by the trigger.)
Am I better off sticking with the dremel and a pipecleaner or going to the q-tip and my drill (perhaps after practicing on stock wheels?)
Dr. T
