I posted this in another thread but thought it may just be worth asking in a new topic instead of hijacking someone elses.
My son's car (tiger cub) I noticed had a bad rear end drifting/death wobble when running in the pack. His car still smoked everyone in the pack on an aluminum track but the seems were horrible. Our car won every heat and the only time it almost got beat was when it jumped on a bad seem. There really was only one other car that looked like they put in quality time on it so it and they didn't have the starter wired to the finish to get total time. I know from when I was in scouts there there are plenty of serious cars at district. They use the same track for districts but I am hoping the main guy that coordinates that will shim the seems to line up better. When we put it together for the pack most of the seems were clamped using those large black clamps used for office paper instead of good shop clamps.
For his build setup we didn't do any canting but polished the stock BSA axles really good and burnished the wheels with hobb-e-lube. It is a 3 wheeler that naturally turned toward the lifted wheel but I didn't do any tuning for the pack but now that I have learned more and saw it run I wanted to tune it up better. I think it may be too aggressive I just rolled it on a 3.5 ft table leaf and it went at least 5". I will be bending the DFW to start tuning the steer. I am debating whether to cant the back axles and try to tune them so they run true. I think they are fighting each other and the back wheel opposite the DFW pulls into the rail too. I already pulled the wheels off and can tell the back are hitting the body some since there are hub marks around the axle holes. If I don't use an axle bending tool is it dangerous to try to do that for the 2 back wheels, cutting a notch and tapping with a flathead and hammer? Will it just create even more problems since the 2 back axles may not be bent exactly the same? We can't make screw slots in the heads but I was going to drill access holes to avoid turning the axle with nail head
