We usually race a long wheel base car for our pinewood derbies, however we wanted to try a shorter (5 inch) wheel base car, esp since all the pros seem to race that setup. When we tested this car on our wooden test track we ended up being slower than the longer wheel base, which is counter intuitive since a shorter should be faster. Both cars are running the same wheels (we switch them out) and same steer (~3-4 inch over 4 feet), and the same weight setup, ~2.05 ounch behind the wheels the rest in front, slightly biased towards DFW. The longer wheel base frame weights about 11.2 grams and the shorter about 10 grams. So the shorter wheel base car has some extra putty to get it to the same weight. I know a lot depends on how straight you drill the axle holes (both drilled with the same jig, which I know isn't a guarantee for same results) so maybe the longer wheel base car has better alignment. My question is, is their a different optimum weight setup for a shorter vs longer wheel base car, should we put more weight behind the rear axle with one the wheel bases or should the same weight setup give similar results? Or is their something else we are missing? We will play around with it a little but I thought maybe the experts can chime in and point me in the right direction.
