Gents
I came across some information in regards to weight displacement on another forum and would like to get your thoughts on it.
In the first picture is the weight configuration I was planning to use. My understanding from reading other people comments is that for the best results I should have my weights as low as possible with as much weight in the back while still maintaining a COG of around 3/4 ~ 5/8 (which is what I have here). My assumption is by having as much weight as possible in the back, you get that little extra push coming off the down slope.
Now I also assume that once you're flat and level this advantage becomes neutral.
Now this one gentlemen stated that if you compress all your weights with in the diameter of your rear wheels, as I have done in the picture below, you will have better results. (By the way, I was able to achieve the same COG this way as in the photo above.) In order to do this I had to stack my weights higher.
This is the first time I've heard of this type of weight distribution and I'm just having a little trouble understanding how his method is better than the way I had it set up above. If anyone can explain his concept better, I would appreciate it.
